Mugabetown - Whoretownin' At It's Worst.
I want this http://www.hioctanedirect.com/index.php?main_page=product_info&cPath=5_148&products_id=553
but it is worth in the same ball park as the new car, life is annoying
Well, when you include shipping, customs and GST, it is very close to a new car!
why? your car was already built not too long ago???
Why would you spend $25K on going through all that again for more cubes?????
Dont be silly Bunta, use the funds you have to buy the car you mentioned before and with any other disposable income you may have fix the GTR i.e. crank trigger, tuning etc....
Because OS Giken 30! Cant find the long motors anymore which sucks, they were good, ready to drop in including adapter plate
Ok guys, have had a think and chat to a few different people regarding Clint's perma ban.
The general consensus is that a ban was warranted, but not a perma ban.
I've raised this with Duncan, who is the Admin who started that thread and Revhead, our admin.
Now comes the time where I can push it further and push for answers, or let it go and remain placid.
My question to you guys is, if you were in my shoes, how would you deal with it?
Don't just give me yes or no, thoughtful responses would be more useful.
Thanks,
Tony
Few thoughts.
Dealing with it in the open here is unlikely to please the people in charge or do anything other than fire up the locals and start some sort of whorpocalypse
Unless we know what was said we cant really frame our responses, Did it sound like Duncan and Revhead are inclined to do anything about it?
Does Clint even WANT to come back? He didnt sound too keen the other day
Few thoughts.
Reason I did it out in the open is because history has shown this stuff will get derailed very quickly.
Neither Duncan nor Revhead have responded.
I really don't know about Clint.
Since the above two factors are in the air, that's why I thought to ask others. Move it to Members maybe?
I would say that's the most appropriate place to deal with it
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
