Mugabetown - Whoretownin' At It's Worst.
That means that you made losta kesh monies that year. :)
I couldnt lose that year, Highlights included buying 2500 Evaan Deakin shares for 3.35 and selling them at 18.80 somthing when they got bought out by Downer EDI and buying 1800 NAB shares when they dropped to 21 bucks on the first day of the financial crisis then bounced back to 28 3 days later.
Edited by Bunta
Dude! Well played! That's excellent work. I bought cochlear at $65 on the word that big news was coming out.
The news was that they f**ked up and had a recall...
Yeah... Wasn't too happy. Have had to sell everything over the last year though. :(
Yeah we have sold almost all of it over the last few years too, a lot of it went into a home deposit though
A lot of it went into just pulling through. :/
Oh well these things happen. Worked out any other movies yet?
but at least u have a home now mate.
Shares trading takes time and money. They provide a high return to the ones that have an understanding of market trends, make quick decisions and willing to accept higher risk should they not hedge effectively.
TBH if u had $1,000,000 u would have made more money just by placing this in a high interest bearing a/c than placing it on the ASX due to its extreme volatility during the last 5 years.
But then again I'm a risk averse individual. Someone with the tools and experience would of capitalized on that on the ASX.
you can avoid some of it, but if you make a lot there is no avoiding it fully, I am still disturbed by the 18k bill year :( lol
your just naturally disturbed Bunts. U should be used to it. Time to think of it that bill cost as much as my engine wow!
Shares for home is a trade I would make every time, the last year has been really good, even with the ass f**king we got from the body corporate
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
