Mugabetown - Whoretownin' At It's Worst.
Has anyone else noticed the pressure in their tap kings dropping?
Have you been washing the tap out? Blockage would be the only thing that would cause it to flow slower. The gas is in the bottle so should be the same all the time
Didn't see the need as I've only been using the same beer. Shall try that.
I heart chancer!
I too have 40k stuff. Have painted since I was about 10. Don't care much for the game itself. I thought your name must have been 40k related.
Indeed it is. I'm more into the painting and modeling side of things these days. Built a decent sized Black templar army and started nids and just sort of started collecting individual models and the occasional squad and spending over 12 months painting XD
Not getting any gas. No head. :/
Nothing. Bored at home. Watching tv and waiting for chants to bring me beer.
Get Brooklyn nine nine and Dad's (new tv shows out)
^ This
Dude you need to wash it. Bet contains yeast and sugar. You will get all sorts of gross stuff growing in there then getting pushed out into your first beer.
Cool. I did chaos for many years. Started dark angels this time last year. I do have a soft spot for templars!
Tau Empire is the shit
Where is the resident templar? There is purging to be done! Lol
Just grab the trusty baneblade and take emperors champion into battle for a sure win :P
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
    • A wise man once told me, "Anything you enjoyed wasting was not wasted".
