Mugabetown - Whoretownin' At It's Worst.
Sorry, up the road towards city. Units next to the servo (used to be BP?) and Dominos (possibly still there???)
Right near where that mechanic crashed the customers porsche and died couple of years back.
Ahh i see, its a 7/11 servo now and dominos is still there, that's pretty close to my place.
The Breeze is good down there, we go to the park to do our work outs by the river, great spot for it.
Everyone thought it would never flood again I think!
Well if they didn't use wivenhoe as water storage we wouldn't have had the problem in the first place :/
Well it is designed with both storage (46% of capacity) and flood mitigation in mind (54%) and is only designed to reduce peak height by a meter, it achieved this in 2011. It was peoples expectations that failed rather than the dam! Most of the water came out of the Lockyer anyway which joins the Brisbane River below the dam, it was all just a series or really unfortunate events.
Yeah I guess. Then started the blame game :/
Yeah, the flood commission was a total joke with the finger pointing, some of my measurments got submitted as evidence to that, had to go and sit there for a day, terrible waste of everyone's time!
Such a fun job :P Do you often get questioned regarding the validity of the data you provide?
Always
Yeah although it's not the best image to have the exec arguing publicly like that :P
Just start a little earlier ;) by the time we get there only the crying is left
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
