Mugabetown - Whoretownin' At It's Worst.
With this much Notice you should e able to organise to be down here, right? :)
guy who could cover for me is on rnr that week anyway, and with Christmas so close its harder to jiggle things around, so probably not unfortunately.
well that sux Mell
Because it's been raining today tho it will be dead quiet I could probably nap at my desk until 2 and nobody would be effected lol no calls yet and I've been here and hour and a half..
Damn accountants. Wouldn't trust them.
What have we got here now?
Lawyer
Accountant
Management consultant
Sparklers
I make people run... Then give massages... But no happy endings given...
I'll take a happy ending. ;)
Also, just realised that sparkies got auto corrected to sparklers. :P
No happy ending for you, happy for me when I make you workout hard enough you spew :) Hahaha! Joys of being a PT...
Oh and there is also a Cabinet Maker in here too...
Sarp mangs. Scarnon around here?
Last big pour today. DJs topped out after 20 odd months. Lucky bastards we dont finish the last of the concrete till Xmas.
Lots has changed though
Feb 2012
https://db.tt/9oD0kXsb
Now
https://db.tt/yvuDhfH4
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
