Mugabetown - Whoretownin' At It's Worst.
Night all. Hopefully get the leopard back from the auto elecies tomorrow so we can rip it apart and fix it all up for Martin
I'll tell you what. The boss is giving this one the treatment, noting everything and even things it didn't come in for :P
I think imports are growing on him hahahh time will tell
How's this. The auto shop guy walks in looks underneath at the auto and the bottom of the engine for 20 seconds and says vg30, same gear as a z32
sounds like he is good at what he does then
Yes well, where were u two years ago Chantelle! Wahhhh :(
I was living in Bendigo with a 2 year old and an idiot, cruising in my Skyline and working my butt off at Uni
No. No. Not same gear as z32. Z32 is TT this is T. Also, the racks are very different.
Spoke with Richo yesterday about the build. Long story short, falling a few days behind firs estimate due to new 2000cc injectors being too tall and fouling on the plenum. Re ordered some smaller ones to suit. Downgraded to 1200's, not ideal but still more than big enough for what the rest of the car will be able to handle at this stage. I think i wil go through gearbox & diff before I need bigger injectors
You are correct Andy, I'm at the "Not really bothered stage" in regards to time its taking to be ready. I was more annoyed about not being able to stick with the injector size I preferred. Richo said the Dump/screamer setup is awesome though
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
