Mugabetown - Whoretownin' At It's Worst.
Shame. Always good to let the builder to do the tune :(
Hopefully it all turns out ok in the end.
Out of interest, how much are you expecting this 'run in tune' to cost?
Tomei built it.
The only person who knows what is going on is Sean. At the end of the day, he is a great tuner and hence why we have him on as a sponsor. He has a great deal of knowledge with these motors and also has a number of supporters. A lot of the people that use him speak greatly of what he does. However, not everyone uses him and anyone that has either built a car or required a major re-tune will tell you that these things take a lot of time.
I can appreciate that it is difficult from your end as you just want your car back. Although it's been 3 weeks since you delivered it to Sean, there has been a few things that have come up in that time.
1) the fuel pump
2) he fell ill for a week
3) Jambo - a massive marketing opportunity for him that probably results in a lot of revenue for his business
4) the ECU
The added difficulty is when you have people who haven't built a car before asking why it hasn't been done yet. You've got a brand new engine which is worth some decent coin along with some very nice go-fast bits, you don't want this rushed and botched.
My 2c, speak to Sean and try and maintain a positive frame of mind. :) I know that it isn't easy, but that's what you need to do.
Bunta and Colin had theirs tuned there and they were both quite nice and white and 32s and GT-Rs.... Creepy :P
+1 to this. The people outside of this situation are being quite inflammatory, insinuating somthing is broken, or that the tuner is being underhanded ect. Its not at all helpful to Ants or one of our club sponsors.
Ants, my advice is this. If you want an update every few days, ring up and ask. Every work shop I have ever dealt with operates like this. None of them will ring you unless they need something or its done.
Everyone else shut the f**k up!!!!
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
