Mugabetown - Whoretownin' At It's Worst.
Shame. Always good to let the builder to do the tune :(
Hopefully it all turns out ok in the end.
Out of interest, how much are you expecting this 'run in tune' to cost?
Tomei built it.
The only person who knows what is going on is Sean. At the end of the day, he is a great tuner and hence why we have him on as a sponsor. He has a great deal of knowledge with these motors and also has a number of supporters. A lot of the people that use him speak greatly of what he does. However, not everyone uses him and anyone that has either built a car or required a major re-tune will tell you that these things take a lot of time.
I can appreciate that it is difficult from your end as you just want your car back. Although it's been 3 weeks since you delivered it to Sean, there has been a few things that have come up in that time.
1) the fuel pump
2) he fell ill for a week
3) Jambo - a massive marketing opportunity for him that probably results in a lot of revenue for his business
4) the ECU
The added difficulty is when you have people who haven't built a car before asking why it hasn't been done yet. You've got a brand new engine which is worth some decent coin along with some very nice go-fast bits, you don't want this rushed and botched.
My 2c, speak to Sean and try and maintain a positive frame of mind. :) I know that it isn't easy, but that's what you need to do.
Bunta and Colin had theirs tuned there and they were both quite nice and white and 32s and GT-Rs.... Creepy :P
+1 to this. The people outside of this situation are being quite inflammatory, insinuating somthing is broken, or that the tuner is being underhanded ect. Its not at all helpful to Ants or one of our club sponsors.
Ants, my advice is this. If you want an update every few days, ring up and ask. Every work shop I have ever dealt with operates like this. None of them will ring you unless they need something or its done.
Everyone else shut the f**k up!!!!
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
