Mugabetown - Whoretownin' At It's Worst.
Can we get a full stop in there somewhere?
There. were. Three. Right. At. The. Very. End. Looked. Like. This...
f**k punctuation I was using the shit tablet that I am going to replace and its flat out putting the correct words in let alone keeping up with actual sentences.
Wow, slow night on thread
And what happened to Melly - F111. Flew in for a Riverfire Optus dump, burn and then retired from thread lol
I was at work, again... Story of my life...
Punctuation is serious business.
I've been sick for close to 4 days therefore barely eaten because o can't physically stomach food and still working numerous jobs, punctuation is the least of my concerns right now.
On that note I'm in a pissy ass mood so going to sleep.
Night all
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
