Mugabetown - Whoretownin' At It's Worst.
Congratulations Ants and Mrs Ants!
Natural birth all the way I'm lucky that my wife went Natural twice as well, don't think I could of handle the C section.
hear that! Although gore doesn't bother me. It's witnessing someone else that you care about suffering that hurts.
Good on you and your wife for promoting natural births. That's tops ;)
pretty keen even though I'll be lagging behind everyone with the n/a I shall build my way up tree when I get my opens license
dont care if it's na mate. It's about bringing the club together as one unit not individual units.
Ur part of it should you wish to be part it.welk that's how I c it :)
So I can drive a manual, not bad but not as good as some people, well I drive a manual like a normal person. Jump in a skyline with your bf, and your the worst manual driver ever.... Can't sports shift, but can excelerate fast :)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
