Mugabetown - Whoretownin' At It's Worst.
Congratulations Ants and Mrs Ants!
Natural birth all the way I'm lucky that my wife went Natural twice as well, don't think I could of handle the C section.
Natural is the way to go.
Good to see more people getting into it naturals. Tyler was 100% natural and drug free.
Gawd no. I can just hear you all whispering about which mointain to take it over first.
We are a very large sometimes deranged family here at SAU, I know that if any of our members were in need we'd have 5 plus people offering to help
And this is why everyone loves sau coz we know someone will always offer to help and visa versa and we are always willing to help someone out if we can
Charity cruise is already costing us hundreds of dollars! Gotta try and make some back. Will check the roster later to confirm.
And we appreciate everything that yourself and Anna are putting into it. :)
If you could swap shifts or something it would be good but if not, it's all good
Still finding it a little humorous in that we planned a date that wouldn't clash with cricket to accommodate but you have work. Lol! :P
f**king falcoon has a leaking water pump f**k it all what f**king next :angry:
should be relatively easy to source and cheap to fix mate.
I will would look at sHITBay first.
If u have problems let me know bro
Such bullshit... Why does everything have to f**k up at once. Every time I get slightly ahead with something *finding and buying step 2* something has to break
thats true economic cycle mate and happens to everyone.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
