Mugabetown - Whoretownin' At It's Worst.
Charity Cruise has been moved to the 8th of December,
A number of people who have been critical in the planning process aren't available on the 7th and it's not the right thing to do. Hence we have moved to the original plan of the 8th.
f**king falcoon has a leaking water pump f**k it all what f**king next :angry:
Such bullshit... Why does everything have to f**k up at once. Every time I get slightly ahead with something *finding and buying step 2* something has to break
Mmm being stuck at work serving dipstick flamin mongrel f**k wanker customers isn't helping
Good news is that your day doesn't sound capable of getting any worse :)
How's Anna? Did she go to the Docs?
The doctors said not to bother, they think we found the problem so we just have to wait for it to get out of her system now, They gave a different antihistamine which made her a lot better this morning compared to when she went to bed
Damn it! Colin is selling a reasonably priced exhaust but I am teh broke. I think its time to quiet the unicorn down, I am going to cop a real reaming at some stage if I don't do something about it!
Excellent news! Was it the thing that she mentioned on Faceparty?
The kaki? That's an impressive exhaust if it's anything like their other products.
I dunno what she mentioned on there but it was a tablet she was taking, A month ago she switched from the generic to the regular one and a few days later she was itchy and a few weeks after that hives, She stopped taking it a few days ago and things have started to get slowly better since then.
yeah, i had one on my R33 at one point, was good, quiet with out being too lame.
Will miss how my car sounds now though :'( stupid laws
That was it. Hope that she gets well soon mate. She's too awesome to get ill. Tell her I said that :P
I think by tomorrow morning she will be close to 100% if current progress is anything to go by.
Will do
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
