Mugabetown - Whoretownin' At It's Worst.
It was reasonably good. The refs were bad, but the team I have been a fan of since I was 5 won so I am happy. The Roosters were 18 to 8 down at one stage and won 26 to 18 so it was a good come back.
sounds like it was a good game indeed.
what work do u do Scottie?
Should be paid double time, no?
I work in the Golf Industry Ants. I get an extra RDO so in theory its like getting double time i guess, doesnt feel the same though.
Your build thread was getting some early morning attention today also. Feel sorry for you r email inbox with all the new posts lol
thats right I forgot!
Yes, I quickly saw there was some activity on my build thread.
Hoping to do a little work on the car today......nothing complicated but will stick the N1 bonnet garnish on the car
Should look nice
Morning People, Mine is staying in the Shed for now. She needs a service, bang on 5000k's now.
i once went 12,000km without a service on mine **Hangs head in same**
It was at a time i was driving to brisbane and back everyday in it and contemplated selling it for something comfier to drive etc. Decided it better to get a new job instead closer to home
Always do, Just haven't got it in the budget this week.
Next week I will service it.
understandable. I like doing the general service on cars. Anything more complex though will go to a mech.......which reminds me. I need to find a good one that has more than 3 qualified mechanics
Yeah, I did that with my 33. I am trying to be stricter with the 34's servicing. I would do it now except i want to put royal purple in it and that's $100 right there, not to mention the KnN oil filter, plugs and the Air filter cleaning Kit.
understandable. I like doing the general service on cars. Anything more complex though will go to a mech.......which reminds me. I need to find a good one that has more than 3 skyline qualified mechanics
FYP
plugs? As in new plugs or plug cleaning kit
Sooo, remember the post from yesterday where some ebay seller used a picture of my car to sell their copy of the drag wing.... I emailed him giving the car a wrap and asked if its his. To which i got a reply stating he is the proud owner of said vehicle
Fk me!
The balls on that guy!
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
    • A wise man once told me, "Anything you enjoyed wasting was not wasted".
