Mugabetown - Whoretownin' At It's Worst.
There's a really nice stealth black R32 in engine bay picks section with powerglide. Have been weighing up options and this approach for something for quick street/drag. Wet clutch, torque multiplication and transbrake for drag would make for a very interesting launch, if the theory meets the real world. Fingers crossed :)
there was a 500kw 32 in town that had a 2 speed in it, but i never got to go in it. had about a 5500rpm stall on it
then again getting hi powered rwd off the line cleanly is all in the launch control/suspension setup and how much rubber you can stick under it
lol look at the advice google gives you on that
also #@Beelzebub89 one for you, go into google on any computer and type in do a barrel roll and press enter.... watch google chuck a fit hahahah
So true. Set up will be drag orientated, but engineered. I get a pretty good supply of used Michelin race slicks from Porsche Cup car. They aren't totally gone, approximately 50%, but won't be using these on street - they are atrocious cold and HWP don't tend to see the positive traction side lol
What do you mean? Hwp love seeing racing slicks on imports on the street. They love that sort of behaviour. :P
On that note, morning all!
Cost/gain analysis - $50 each and no drag bags slapping into arches/guards and better grip than semis
They will have worse grip than streets let down to 20psi. Been there done that, it doesn't work.
On 18" qualifying tyres? This hasn't been my experience.
Yep. They have no side wall and no bag and most of them have seen too many heat cycles too. Good for circuit terribly shite for drag racing. A good set of drag radials picked up .5 of a second in the 60ft. 2 seconds down to 1.5.
The lesson I learned from all this is to use a tyre for what it is built for. If you aren't you are pushing shit up hill.
What a lovely day, and tomorrow is Friday :D
Tis a nice day. I am outside for half of it too. I do have to audit a fish processing plant though. .. bit worried about that, walking past the fish section at coles makes me gag
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
