Mugabetown - Whoretownin' At It's Worst.
just so we are clear, you are aware of the following because of the height difference.
Intercooler pipes wont fit, need to be modified.
exhaust wont fit, needs to be modified.
stock turbo is too small chokes HARD at ~5500 (you end up with about 80kw@ wheels by 6500)
intake pipe will need to be modified unless stock/flexible ish
front strut brace is unlikely to fit
car it came out of was probably automatic, dont forget to change the spigot bush in the crank or you will f**k your input shaft bearings in the gearbox
retaining vct isnt hard, just needs some bundy tube and some patience to run the line from the oil pressure sensor feed.
probably some other things i have forgotten since doing it.
im sure there is a RB30 build thread somewhere that he can follow tits.
Also in case your not aware already
Zac is a mech ;)
One way so solve a lot of thoes, 26 head ;)
There is threads and PDFs and a mountain load of info on them I think I should be pretty right to tackle it. No doubt I will encounter issues but this is a learning experiance and training for me, and not sure on if it will be going in mine or getting sold, ATM if I sell it Kathryn's had already chosen what the money from it is going towards
that only fixes 2 of the issues, strut brace and VCT.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
