Mugabetown - Whoretownin' At It's Worst.
i was thinking it was a next mod for the 33, so his fantastic idea is to replace the waterpump? :unsure:
Nickies water pump on the falcon is fubared tits!
Im sure that his next mod for the a-bomb would be more exciting than said water-pump mate
that evo i posted the graph and such for, same turbo as you.
Mine is a T66 ceramic roller bearing Turbonetics it's a Q trim F1 wheel which is the biggest they fit for T66. I have kept exhaust housing small for spool up. It has a dual fuel system too - three rocket switch panel hidden inside centre console. Meth tank and twin 044 plus surge in boot and a seperate Walbro in regular tank for 98 fuel. A lot of the details are hidden.
I am off my ps, how do you think I have a v8?
The no fi is due to weight/capacity laws not age, plus I don't wan a glorified pump stuck off my motor, real engines dont need that shit to be quick
Not what a Top Fuel driver would say! lol
Mine is a T66 ceramic roller bearing Turbonetics it's a Q trim F1 wheel which is the biggest they fit for T66. I have kept exhaust housing small for spool up. It has a dual fuel system too - three rocket switch panel hidden inside centre console. Meth tank and twin 044 in boot and a spate Walbro in tank for regular fuel. A lot of the details are hidden.
i meant scotts car, the one pictured above.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
