Mugabetown - Whoretownin' At It's Worst.
Struggled getting the crank bolt out more than the pulley got the bolt out. Ballancer came with a few taps and then the pulley just slid off
No damage to crank, key way or pulle which is a good sign
I think after looking at the 31 on the weekend Matty is keen on we will head back to mine and strip it right down
Now the rest of the week is for research and looking for parts ;)
Suggestions people, let them come!!! Just thought of this. Would a stroker be worth it or not?
Dude I'll probably be taking it home aha
How's my car?
Crank timing gear have any surface rust on inside?
Nitto Rods and pistons (Nitto/JE) on prepped RB30 crank or go the 3.2 big kahuna :) I can put you in touch with Andrew from Nitto, if you'd like to talk to him. He's a mate and lives 10 mins up the road. He's very approachable and helpful with info. Ask about Nitto materials and design R&D it's incredible.
