Mugabetown - Whoretownin' At It's Worst.
car looks mint. Says GC. I wonder where?
Could check it out!
On the southern end of the coast I think. It's a car I know relatively well. It lived at efi for a while there when the owner was in the mines.
I seriously nearly bought it :) Freight company couldn't sought their shizzzz out and the delay meant the car sold to another buyer in US in the interim :(
u have to many cars already man
I keep modifying them and once I start... I figure I might as keep them, as a sale would mean the equivalent of me selling the car for the same value I bought it at and writing a cheque for big $ and just handing it to someone else. I'll post a pic of what I got instead of Datto :)
