Mugabetown - Whoretownin' At It's Worst.
That is true. But she might want to learn to drive fast as well after she gets her turbo.
Worry about that when the time comes, the likely hood she'll keep it and do the swap is low (sorry kat but the odds are against you keeping it)
It takes a very very strong bond with a particular car to want to drop money on it when you know there is a cheaper route
Its unregistered so car trailer it is... Nah I don't want it to be loud. All skylines I've heard are to loud. I want a quiet one.
Mines not loud at all... Keen for straight pipe sidies lol
This.
Yeah I guess :P are we allowd to pay on the day?? Cos I'm not sure if zac paid for me :/
Yeah but it's better for us if you pay beforehand. Did you have fun with martin last time?
Also you coming for a ride in the SS at happy laps Kathryn?
As much as it was ok having the little dude I took around last time I'd really prefer not to have anyone in the car this time around with me
Ahhhhh the stealth approach, very sensible. I still haven't managed to come around to this approach - I actually enjoy arguing the police powers and road traffic act with the 50 :)
Well I have Connie this time but I also like being on my own. I might even let her have a drive ;)
'Twas fun :)
How much is it and how do I pay??
$35 and you can pay on the day if you want, otherwise bank transfer.
Haha mine draws loud as for a natro, pod filter ftw lol
Yeah cheap supershit pod + home made pod box = mad induction.
So I'm gunna have to bring the car trailer to happy laps and get my car after happy laps...
Looks like it. Trailer Zac's 33 out.
Not familiar with that acronym except it's traditional 80s implications, namely Autoimmune Immunodeficiency Syndrome? Last time I checked cars of any species cannot catch it :)
A wet nitrous kit will not fix AIDS.
I dunno what you've been attempting, but I don't love cars this much lol
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
