Mugabetown - Whoretownin' At It's Worst.
No. there was a guy here on SAU that built an N/A RB30 stroker full of expensive internals - it was uninspiring. Just wait for turbo.
negative.
26/30 was done into a 31, sounded cool, made about 200kw. a turbo 25 will walk all over it with just a couple small mods.
This was the same car I think. build was on forum?
Cant p platers get turbos based and power to weight now? If you must have a skyline get a 32 gtst with the 20 in it.
If it has to be na then get a silvia. Heaps better na than any skyline. Or wait until you're off your ps and then do it. Nobody ever wants to hear that but it has its merits. Skylines will still be around in 2 years
Nah, buy something with a 13b Bridgeport, much more fun :)
So just looking at what your talking about and it does sound like a bad idea. Also getting prepared for a turbo when your off your ps might not even happen, you might get bored, or things might happen, do what you have to do to it on your ps, you have 2 years on your ps still, that's a long time and you never know, things happen. Having a skyline comes with great responsibility, a sense of honor and you have to keep a good reputation for skylines and the club your a part of. So don't do anything stupid with your car, or make it so that police will ream you. You have to think about what your doing and not just think power, you have to think about everything and everyone else you might effect.
Hello all :)
negative.
I'm just gonna go dirty 30 I've heard you can get big
Numbers easily?
So just looking at what your talking about and it does sound like a bad idea. Also getting prepared for a turbo when your off your ps might not even happen, you might get bored, or things might happen, do what you have to do to it on your ps, you have 2 years on your ps still, that's a long time and you never know, things happen. Having a skyline comes with great responsibility, a sense of honor and you have to keep a good reputation for skylines and the club your a part of. So don't do anything stupid with your car, or make it so that police will handcuff, bend you over your bonnet and take immense pleasure in reaming you curbside. You have to think about what your doing and not just think power, you have to think about everything and everyone else you might effect.
Hello all :)
FYP lol
Numbers easily?
high 300's with a gt35 and with the right manifold/exhaust can make full boost at 3500.
would i suggest that as a daily? not so much, too laggy? not really, but it is too much power for general street duties when you need wide semis just to avoid spinning 3rd when it comes on boost.
Hello all :)
I have learnt from past mistakes I very rarely creep over the speed limit and haven't done one skid since I've had my license back
Depends on what you want it for. It's all relative and depends on what you consider big numbers. Anything involving a built motor you better be ready to dump 10-20k in it. Looking at any of the engine builds on this forum you can see how they can spiral out of control. Not to mention anything that goes wrong and the time it takes to actually get it all sorted.
In saying that you could buy everything second hand slap it together and put an ebay spec turbo kit on it and crack 300kw pretty easily.
We make a lot of significant' stuff for mining projects (and import a fair share more of it too, to be fair), its just that that isn't a sustainable manufacturing industry.
If you would be so kind :yucky:
Sorry if i rubbed you up the wrong way there, but it twas a busy day in here yesterday
thats ok Pete. But realistically this place is not going to slow down unless it's somehow shut down.
Which I sincerely hope does not occur.
Nick's right. The machining costs alone are astronomical. It has been done time and time again and the results quite frankly sucked.
You can't have turbo compression on an n/a built motor either, the thing would be a pig.
this ^ listen to this ^
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
