Mugabetown - Whoretownin' At It's Worst.
Wearing sneakers for sneaking...
I am going to try and service my car for Sunday and If I can come out and Play I will
Do eeeet I'm keen to see how The Galah goes, drag strip wasn't a fair representation
Go at your own pace, perfect oportunity to get some coaching too from a more experienced driver. Most of the guys wouldn't have an issue with doina a few laps in the passenger seat and helping with some pointers. Confidence and coaching help develop driver skills. That and a whole lot of practice.
pretty much all of this ^^^
I just hate how they hide then send a ticket in the mail 2 weeks later.. would rather be pulled over then and there so I know of shit I'm in trouble where now I'm more annoyed I didn't see them or remember if I was actually speeding or not.. might just look into a gps tracker to log speed.
Happy laps this weekend will take my frustration out on track :D
Was it from one of the new speed cameras? Check the image and see it has all the info speed, date etc. There have been a few cases recently of fines being overturned because the captured image doesnt have all the information on it. The new true cam speed cameras dont do it all.
Worth checking before you go and pay money for something you can get out of.
    • Hi. This is just my curiosity because iam sure the tuner figure something out...but either way i want to ask. The "problem" is that the Nistune ECU (Stagea FW and RB25DET NEO from Stagea) sees many times the speed than the speedo does(he says the speedo show 120 km/h - correct speed and the ECU shows like 510km/h ) I told him that this car/tranny getting speed from rear diff. If iam not mistaken the RB25DET NEO "need" to see tranny speed sensor? (my tranny has the plug for it). So couple of "question" If he connects/wire the speed sensor to the tranny...are the signals gonna intervene and if...what if he disconnects the rear diff one and the speedo stops working? Or the "new" sensor from the tranny "take over" and will not going need the one from diff? As i said i know he figure/get that done...iam just curious to know what are the solutions 🙂
    • Your IACV is set to idle too low. You need to adjust it via the screw Duncan mentioned. From memory it should be 650rpm with the valve electrics unplugged. What is it trying to idle at with the IACV plugged in?
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
