Mugabetown - Whoretownin' At It's Worst.
What insurance companies are best to insure skyline with?? For an under 25 year old :/
Most insurers wont touch you with a 40ft poll
NRMA will do fire\theft
Shannons & Just Car also
Allianz wont do it
This will cheer you up. AMS GTR v Lambo insane acceleration in third gear http://www.undergroundracing.com/videos.html?curVid=uCqbg8akOmA
OMG! Those gallardos ........I want one.
Just can't beat power to weight!
Does sound very good. Love the speedo blistering through the speeds......
Still can't believe the AMS GTR got chopped!
Sound in R8 V10 awesome - It's same as lambo motor but sounds insane in R8.
I know, I couldn't believe it either. This is how I came across the car.
Allianz wont do it
Nrma had a great comp and third and theft
Shannon's I yelled at and called them d!!cks
And suncorp was supportive cos the chick had a supra haha
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
