Mugabetown - Whoretownin' At It's Worst.
Blood stains, ball gowns, trashin' the hotel room,
We don't care, we're driving Cadillacs in our dreams.
Look out the national pimp and Cinderella ballet group are on the loose again
Air con is to cold and I can hear my watch ticking it's so quiet in class :/ needs more fun
Crush up a whole bunch of chalk, place on top of stopped fan, complain kt the teacher that it's hot and get her to turn it on.... FUN! :O
No fans
Hmm, wait till the teacher isn't looking and sharpen a pencil a whole bunch of times so u have a lot of shavings.... Casually drop them in the teachers coffee as you leave. U won't see the results but you can laugh in your own head
