Mugabetown - Whoretownin' At It's Worst.
4 1080p monitors linked with eyefinity would handle it, if you had a way to mount them, but you would still have the split between them, and it kind of defeats the point, which is about higher pixel density, not just bigger screens.
Bingo
what is eyefinity?
AMD's thing that they do with their videocards that allows you to hook up large numbers of displays, not just the 2 or 3 that you used to be able to do
link
I'm honestly kind of dissapointed that by this point 16:10 is effectively dead now in terms of monitors.
