Mugabetown - Whoretownin' At It's Worst.
Have you modified anything on the car zeke?
Or is she stock at the rock
FMIC, pod filter, boost tee upping it to 10PSi, spark plugs are gapped to 0.8 instead of 1.0. 18x8 wheels, 3" Xforce zaust with 3.5" tip, 200CPi metal venom high flow cat.
Old man's commo blew a heater hose off the valve today...farking commos breaking. It split its radiator about 6 months ago, looks like Holden wants them to destroy their cooling systems and overheat.
lol u been given it some boot Mikie hence why breakin :P
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
