Mugabetown - Whoretownin' At It's Worst.
tell me more about the coil overs!?
2 sets, no leaks etc.
1 set JIC Magic, quality jap gear. Hard rates tho, perfect for track work or mountains. Think they are 8 and 10 or 7 and 9.
1 set Tein SS, better for Brisbane shit roads.
It's not mine. It's for everyone in the QLD section. :)
I didn't even name it Mugabetown, that was Scott's doing
actually that was my doing re: Mugabe Town :P
Welcome back anyways :)
I think he took it and made it the title - bastard.
Busy man. Really busy.
CC almost sorted. Events list for 2014 going up today. How's things on your end?
at work trying to sort out as much as I can before I leave o/s.
But all good.
Gonna smash some bills out to a few wealthy clients for Xmas lol
But all good.
Lol! They should suffer and pay bills because they're wealthy?
you really think any of us Qlders are really gonna help you?
Seriously Paulie...................................dafuq mang????
kiddin.......
Where abouts in Jacobs Wells and has the parts been paid for or is the gansta B&E situation?
Not paid for yet bro just waiting for him to give the thumbs up! Don't know where he just said Jacobs wells
Did a heap of air leak fixes new fuel filter, spark plugs and still car is miss firing
Taking off a coil pack off at revs changes it on all cylinders...
Injectors are ticking seems louder ticks than normal but could just be me atm
About to give up on this car anyone got suggestions what to try next??
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
