Mugabetown - Whoretownin' At It's Worst.
What about the green fairy? :)
Did a night out in toowoomba 3 weeks ago and only drank shots absinth and chartreuse... Being that drunk in a club you're worried if you let go of the banister you'll fall over and then you start thinking was that broad minded personty "cheerleader"(it was Halloween weekend) you were dancing with actually hot or was she just broad minded persontily dressed to give the illusion of being hot....
Fcking auto correct I meant s.lutily
Yes the fairy does that pretty quick. The trick is get in while they're still hot, b/c next morning is like being in a horror movie lol
5am when the music stops and the lights come on and shit gets real
Apparently Rajab was from some dude that crapped on about a certain highly controversial subject. now it means that subject and nobody knows where he posted his rants.
sounds similar to panel gaps
Panel gaps
Panel gaps
Panel gaps
Panel gaps
Ahhhhhh........,.that felt good
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
