Mugabetown - Whoretownin' At It's Worst.
Eh hang around here long enough and it won't matter about broken tags, we're an interesting bunch lol
Many new people? Remember I know most of the people. I have been around these forums for a year or two....
Well, more accurately you'd need to ask 2 questions there:
1. Do I want any experience building LS motors?
2. Do you really need to build an LS motor?
Sean at EFI had those things almost scraping 800hp at the tyres with reliability not being an issue whatsoever
Well... I have a dismantled ls1 motor in my shed and am chasing some decent numbers, but here's the catch *takes deep inhale* We need to do it naturally aspirated due to mod plate BS
Hidden NOS might/may/could possibly be an option for someone (rant proofed lol)
New people, well pretty much everyone man... The club kinda disintegrated within itself after some falling outs that occurred *not to be discussed in public* but yer lots of new guys, myself included I guess.
Only really OG people around now are bunta (andrew) and Ants (er ants lol)... Noel's never around anymore and Dave (rhino rebel) only occasionally pops up.
But us new folk are good value :wave:
Oh ok, Yeah I can build anything you want. Engines I'm not familiar with I just refuse to offer advise on part selection and tech shit really. I'm not going to tell you what cam is best or whatever but all engines are the same on the inside essentially. Some are better designed, however.
Where I'm working at the moment is a Jeep specialist so I've been doing quite a bit of different stuff lately. A few 4.7 Hemis, a couple of 1943-5 Willys Jeep engines and a 1945 Dodge Weapons Carrier. Your LS1 wouldn't be an issue
Don't you love auto correct lol Imagine ordering that and coke in a bar lol
I cannot imagine ordering that beverage on account of the fact it tastes like shit haha!!
Let's see if they filtered out any decent Whiskey?
Lagavulin
Laphroaig
Caol Ila
Talisker
Nick upgrade to a hemi
  • Like 2
They're a super complex intricate mind field maze of an engine definitely super technical and difficult lol
Working for a jeep dealership that's Different avenue man how'd that come about
Animal? Bacon is Bacon....it doesn't come from an animal, it comes from heaven
Homer: Are you saying you're never going to eat any animal again? What about bacon?
Lisa: No.
Homer: Ham?
Lisa: No.
Homer: Pork chops?
Lisa: Dad, those all come from the same animal.
Homer: Heh heh heh. Ooh, yeah, right, Lisa. A wonderful, magical animal.
  • Like 1
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
