Mugabetown - Whoretownin' At It's Worst.
Need new tyres and am considering retreads...
Seriously though, finding that 215/55/R17 is not as readily available 225/45/R17 or 215/45/R17.
Would it make much of a difference if I went with one of those sizes?
That's good then, and yeah I wouldn't think a small change like that would throw it out a whole heap but it's normally better to just put the right size on to stop any drama like that
Didn't think that it would matter as tyres aren't always exactly the right size. Some tyres are wider than others although they are the same width. It's because they use metric, fractional and imperial measurements.
Morning all!
