Mugabetown - Whoretownin' At It's Worst.
Was at the Downshift meet as well, its always good fun and you usually get a bit of a laugh. It started to get a bit dull then Angry35, the Vette and the 911 go flying past....was nice to be on track at that time.
Yah had soooooo many issues with my ECU,
wish I could of been out there longer,
an put a better show on for Nick.
I tried to catch you for a run, but we always seemed to be on opposite sides of the track
Yah I was just trying to keep her on the track,
who ever was next to me while it was running right I had a go with LoL
All good bro had an awesome morning scooting around qr in a couple of fast cars :P
#scottandbarneyaretopblokes :thumbsup:
SO the cruise was mad but the organisers had no idea how to deal with bulk numbers as a result it took me 2 hours to get from the meet on to the highway. cops were good but more traffic controll to keep us together like SAPOL do would have been ideal. as a resualt we got onto the highway and cars were spread out everywhere.
Seen a car r33 GTR plate " High RPM" it was drool worthy
