Mugabetown - Whoretownin' At It's Worst.
Seems barney was at the drags yesterday :-)
Ya went for a look see, best time was 11.2 @ 216 km/h my ECU is still acting up
but tune has found problem and should have it fixed soon
No because 2 zeds... Derr...
So 4 oil coolers then...
its all a teething process unfortunately. Still a good time. easily a 10sec car once you get the bugs out.
and Oh so Angry sounding to boot. It is all trial and error until success is achieved.
This ^
I want an 11 second (11.9~ is fine) true street car... I'll get there eventually
This ^
throw some hoosier or MT slicks on the thing, soften up the rear shocks/springs and cam/tune the engine. auto box, 270kw + traction off the line, should get you damn close.
I really need to get down there and have a crack with mine later on in the year [Next Year]
do you care about you clutch? if you want a clean launch, slip the shit out of it with lots of revs through first (easier on dif and drive shafts) with some 16" wheels with slicks or drag suitable semis.
Im currently looking into some 17" or 16" wheels to purchase for this..
if you are ok with modding the rear calipers (need to shave a little bit off to fit them) you can run 15" rims which opens up a whole new world of rubber options for drag use.
There is some MT 15" rims that are mint for same on FB. set for $1000
:devil:
Send me a link bro
Just tagged you in the post on book face. 5x114.3 though so you would need 5 stud conversion. get conversion then we go halves and have two each lol
Here is a pic for those playing at home
  • Like 1
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
