Mugabetown - Whoretownin' At It's Worst.
Hi Ants
Yeah it wasnt too bad.
Spent a few days getting fat down the Goldie.
Hows the kids & the wife?
good to hear Chants.
We also indulged ;)
The kids are fine. It's the parents that are tired.
As you would know :)
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
