Mugabetown - Whoretownin' At It's Worst.
So.......for once that I want to play for just 10min on PS3 (GT5) and I made it clear to my wife 'just ten minutes' (I rarely play it)
I don't even get five and my older daughter is deliberately crawling all over me and my wife tells me 'I don't want to have the PS3 there......move it back in the computer room'
FOR f**kS SAKE!!!!!! I WAS JUST ASKING
FOR TEN MINUTES..........JUST TEN!!!!!!
all this Ls1 in R33 is making me want to do a v8 skyline conversion more and more.
Nice VK56 out of a current infinity, retrofit the AWD system somehow, 320kw's and no turbo lag at all...
Is this because you heard how sexy mine sounded the other day when it lumped into the meet lol
  • Like 1
This would be an acceptable V8 to put in a Skyline.
