Mugabetown - Whoretownin' At It's Worst.
Who has z32's afm's and how on earth did you attach air filtering equipment to them? there seems to be literally no info about how to go about it.
what filter did you get? The filter must be adaptable to 80mm AF meters or else it will never fit!
Still in the office bro.. :(
mate dafaq goin on?
Gettin up early to goto work, stayin late?????
Ask yourself this..............will all my time and effort be rewarded if so...........in what form?
Do not answer that question Tony. Just think about it.
None yet. Don't really want to just bolt a filter onto it sucking in hot air though... but its the last ditch option.
I don't think anyone sells elbows that go on the end to move the pods over a bit in the z32 size, or adapter plates. That being said, adapter plates wouldn't actually be that hard to make
The other option is buying a stock airbox, enlarging the holes 15mm and drilling new bolt holes for the AFM's, as they're in stock location they'll still be flush against the airbox (might be issue with flange protruding past the edges of the airbox face though).
Or i could just buy cheap china spec hard pipe+z32 mounting kit for 300 bucks
mate dafaq goin on?
Thanks for the concern mate. There's actually been a lot going on behind the scenes. Few know. Even fewer understand. Just tried calling and then realised the time. Sorry mate!
Anything that bolts to an RB25DET AFM should also bolt to a Z32 one I think you'll find
all good mate. I was just falling asleep as I could here the phone.
Il call you to catch up.
And morning all
  • Like 1
Morning mate. Really dislike hay fever but that's just a minor inconvenience. Today is going to be a very good day.
thats the way. Got a text message from one of my new clients 10mins ago.......my day will again be interesting to say the least.
Love great starts to the day. Sets everything else in motion.
Last week, had to text a candidate at 5:45 because I had an offer for her. Also messaged another girl at the same time with some other awesome news. Good news = good start to morning = good day.
A custom air box with a neat cold air induction goes a long way I think Pete
exactly why I don't want to just bolt up to the afms directly.
in any case,I think I'm just going to have to wait till I get home to figure out what I'm going to do with them
And nope not me on stage with Taylor, I wouldn't say he was lucky as she now thinks he's a pysco. I'd rather be up there as her lead guitarist :/
them drugs Nick................what I tell you bout them drugs!
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
