Mugabetown - Whoretownin' At It's Worst.
Who has z32's afm's and how on earth did you attach air filtering equipment to them? there seems to be literally no info about how to go about it.
what filter did you get? The filter must be adaptable to 80mm AF meters or else it will never fit!
Still in the office bro.. :(
mate dafaq goin on?
Gettin up early to goto work, stayin late?????
Ask yourself this..............will all my time and effort be rewarded if so...........in what form?
Do not answer that question Tony. Just think about it.
None yet. Don't really want to just bolt a filter onto it sucking in hot air though... but its the last ditch option.
I don't think anyone sells elbows that go on the end to move the pods over a bit in the z32 size, or adapter plates. That being said, adapter plates wouldn't actually be that hard to make
The other option is buying a stock airbox, enlarging the holes 15mm and drilling new bolt holes for the AFM's, as they're in stock location they'll still be flush against the airbox (might be issue with flange protruding past the edges of the airbox face though).
Or i could just buy cheap china spec hard pipe+z32 mounting kit for 300 bucks
mate dafaq goin on?
Thanks for the concern mate. There's actually been a lot going on behind the scenes. Few know. Even fewer understand. Just tried calling and then realised the time. Sorry mate!
Anything that bolts to an RB25DET AFM should also bolt to a Z32 one I think you'll find
all good mate. I was just falling asleep as I could here the phone.
Il call you to catch up.
And morning all
  • Like 1
Morning mate. Really dislike hay fever but that's just a minor inconvenience. Today is going to be a very good day.
thats the way. Got a text message from one of my new clients 10mins ago.......my day will again be interesting to say the least.
Love great starts to the day. Sets everything else in motion.
Last week, had to text a candidate at 5:45 because I had an offer for her. Also messaged another girl at the same time with some other awesome news. Good news = good start to morning = good day.
A custom air box with a neat cold air induction goes a long way I think Pete
exactly why I don't want to just bolt up to the afms directly.
in any case,I think I'm just going to have to wait till I get home to figure out what I'm going to do with them
And nope not me on stage with Taylor, I wouldn't say he was lucky as she now thinks he's a pysco. I'd rather be up there as her lead guitarist :/
them drugs Nick................what I tell you bout them drugs!
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
