Mugabetown - Whoretownin' At It's Worst.
I have 1 or 2 (well really 3 or 4) for sale (however not advertised) atm.
how much? Might be able to build a nice airbox around pods bolted directly on after all, now I've had a bit of a gander at some engine bay pictures
i know man. I wasn't referring to you. I know your naturally slack.
kiddin :P
I was referring to myself in that post.
You're*
Also thinking about starting a DS circuit and coffee thread to throw pictures/things I find interesting at the events into
