Mugabetown - Whoretownin' At It's Worst.
Bah, turbo on the CX-7 has shat itself, can only drive sub 2500rpm....applying throttle results in burning oil smoke out of the PCV :(
Anyone mechanics keen to do the swap-over? The turbo is at the rear of the engine and a real c%$t to get at, name your price :D
Rnr on Wednesday, can't wait to drive my car again, ants I don't know how you've waited so long
Its been 3 weeks for me and I'm dying lol. Ants has great patience.
I did however drive mine for 10mins this morning testing out the new brakes. Verdict, they need more bleeding lol
well I have limited time really. Patience as Scottie said also help but only to a degree.
Everything I do to my car I've basically wanted to do it like yesterday..............it never happens like that
Got a deadline to do my bits. Fuel pump, cam gears, AFM's and injectors need to be in by the time i finish RnR, booked in for a tune on the second day back from my next swing, so hopefully it'll be a whole new beast for... march.
Don't think the injectors have left the states yet though, so might not get them until I head back out to site. Good thing I left myself a spare contingency day.
