Mugabetown - Whoretownin' At It's Worst.
Hi Mr President.
Ready for another epic week?
Damn straight. Yourself?
Got the first part of the training catch up this week. Meeting with a few boys for drinks to get a few things underway! Feeling pumped. Should be an awesome way to finish the week.
For interests sake, if I was to buy a non rego'd car from NSW, that happens to have had an engine swap along the line somewhere (engine number not updated), when I get the car to QLD and in prep for QLD rego, should I notify them of engine number change before I get the mobile roady guy out? Or? From what I remember, the mobile roady guy compared engine numbers before signing off on Cara's zed (which we bought from NSW).
Enlighten me
SKIDS!!! Morning all
Morning Nark. Was thinking this morning, since you're so anti-nissan, maybe you should get brakes from the new HSV. The bus goes past a Holden dealer and I saw the brakes and just thought, why would they need so much stopping power on something that produces SFA horsepower?
Enlighten me
You would need to notify them before the mobile RW guy comes out.
Don't you work for TMR? :P
I thought that might be the case, however, since the car isn't on the QLD books, what would they update exactly?
Hell no I don't work for them, just in one of their buildings ;)
You raise a valid point. They would probably create a shell of the car on their systems and note it accordingly so that it's updated at time of rego - if they ran like an effective corporation.
Sure sure.... :P
I duno dude 435kw needs some stopping, also I didn't cook my brakes on Sunday. I only cook them with you guys cause it's like track day as opposed to line ups
I didn't even think you raced anyone all day lol... Just cruising
good stuff. I'm flat out with deadlines galore this month!
Enlighten me
Had this with Kathryn's car engine had be swapped tmr was not informed
Rodie guy will jut right it down and you go in and regestrring it if the ask you just say if has had a engine replacement, not swap but replacement with the exact same engine
They won't care if it's the same as the old
  • Like 1
Cool, you make it sound nearly too easy lol
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
