Mugabetown - Whoretownin' At It's Worst.
Its not going anywhere at the moment! I sold the AFMs so I need a pipe to replace them. I have the money saved up for the crank trigger and balancer, then I ended up spending all that time away with Mum being sick and I didn't get to do any more. Guess I can get back into it now!
next time you have saved some money aside just spend it on some parts that way you will already by acquiring performance parts as you go.
I had planned to buy as I went, but I have had a dramatic change in finances, so I can just do it all at once now, which will be nice!
cool. keen to see it all happening mate :)
I am probably just going to pay some one to get it all painted too, I admire your abilities in the body work area, but I just cant do it! lol
Morning all
In the emergency room, piece of metal or dirt or something in my eye and it's so painful I can't even keep it closed or open or move it without it feeling like someone is gauging my eye out
Morning all
Shit. That's not a great way to start the day...
Morning all.
So, I'm working with a Partner level candidate who wants to move to Melbourne. Have been speaking with a colleague of mine down there who has constantly assured me that he will speak to this guy and give him the heads up on a few things... Fair enough. Get an email from the candidate, who is very angry, this morning that nobody has contacted him... This dick bag of a colleague has now made me look bad!
Morning all
fark bro! How did that happen? And who's with you at emergency room?
Morning all.
alas shit like that will always happen.
Best to fix it yourself and move forwards.
Good luck anyways
Good luck anyways
Yeah. That's it. I apologised profusely in a reply email and am speaking with him a little later today. Wasn't impressed though.
How's your week been?
a mixed bag this week......started off well, turned to shit on Tuesday and Wednesday, yesterday was better and today will be good..........I think
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
