Mugabetown - Whoretownin' At It's Worst.
Martin 1, Leopard 0.
Had to get the alternator out of the bastard, thought for sure that would be an engine out job, but turns out it isn't! Was quite a battle but I got it out in the end, although there was literally millimetres in it, any worse and it would have been engine out for sure. Not quite sure how I'm going to get it back in :S but will cross that bridge when I get to it.
Also, turns out she has Takata belts, who knew?
How are both the cars Martin?
Leopard will probably be up for sale very soon. Alternator is dead but I'm replacing it, tried that silicone spray trick on the seat belts but it didn't seem to help.
Wedge is going fine. Clutch pedal got noisy the other day but I sprayed a f*ck tonne of silicone spray on it seems to have sorted it out :). Still using oil, haven't looked again to see if it's leaking or burning it though. Probably retire her from daily duties soon so that will give me a chance to sort it out
Re mystery oil burning, In my old R32 i was always losing oil slowly, turned out it was an oil seal in the turbo that just let little bits out constantly, it was a small enough amount that it would burn up instantly and not cause noticeable smoke but it was enough to almost empty the damn sump if you forgot to keep an eye on it!
Does anyone know if the pistons on R34 GTT brakes (F&R) are the same size as Z32 brakes? I know the rotors are different sizes... Not sure about the acutal pistons though...
they are the same Tony
Wish my car came with brembos :(
Will have to get a set of bigger brakes sometime this year. Unsure of direction to go. Kit out of china, Brembo's off of r34, Evo Brembos... lots of choices.
brembos from other cars ie R34 GTR are a poor upgrade...........save and get a big brake kit........I'm not a fan of Chinese brakes hence why I have AP Racing 6 pot brake kit
Brembo F50 / GT kit, Endless, Trust / Alcon all quality brakes but expensive
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
