Mugabetown - Whoretownin' At It's Worst.
Morning all
Gt6?
that and GW2
If bored, and speaking of VW's, jump on youtube and search race taxi.
You are welcome
Is that the split window kombi with porsche engine? if so, it is epic
hey everyone! what's been happening?
I'm no longer a skyline owner but still have something Jap, i Bought a brand new Yamaha XJ6N. Its much better than the car for commuting to work.
I will have a post up soon with some of the left over parts you all might be interested in buying.
I too have some bits and pieces to get rid of
f**ked my back installing brake switch stopper rubbers In my bluebird this arvo. 2hrs is too long to be upside down with a reverse kink in your back
Did a brake booster on my old hand me down Camira.....I know the feeling, next time remove drivers seat.
Morning all.
It's Friday :)
tis indeed.
I am still considering offloading mine. I occasionally get get exited but 90% of the time I couldn't care less and it just sits there undriven. I am no longer interested in track stuff so really it is the wrong car for my interests.
Got a Mazda 3 in today 2009 model
She has had it from new
Had it serviced at 1800
20000
50000 and it's now up to
Wait for it
90000
They are ment to be serviced every 10000
It had about half a liter of oil in the sump
it ain't that difficult Bunts!
It can be, but thats because I have always been buying secondhand cars, so you want THAT particular car, I guess with new it is easier because you can get exactly the same thing elsewhere.
20000
Wait for it
90000
There was a kluger at the mechanics next door to work. Owners purchased it brand new. Had close to 200000kms on it in and was about 2.5 years old. Never had a service or any fluids checked. Engine seized up because no oil and the owner wanted Toyota to fix it under warranty haha
will you be buying new or second hand this time round?
Costs me half as much to insure the new car as the wedge. For about 2.5x the value and for regular use instead of 'once or twice a week'.
F*ck skylines.
No, I'm not selling the wedge :P
sell it and buy a VW beetle
stupid people are stupid.
We had one exactly the same at the old shop I used to work at
Except he had the 1000 check over done and thought that was it. Cars didn't need servicing to run
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
