Mugabetown - Whoretownin' At It's Worst.
Mr ants I also have a question.... But I'm not telling you what it is you must guess
I'm still not really certain how to resolve your GF bisexuality issues....but will think of something
Thank you good sir! Negative gearing wont be a factor as there will be no borrowed money, my brother in law always says to 'buy an investment you can drive past' and like you say real estate is pretty low risk. Seems like property is probably the go
Edited by Bunta
Mangs, scrackin?
Thoughts on S13 as cheap track car? Or any other suggestions, criteria; light, RWD, <$7500, cheap parts/aftermarket support.
Really pretty narrow criteria S13s or cheap 32s are my only thoughts at the moment. Not interested in 32 because f**k RB20s
Pinny cup.
having a Bisexual GF isn't really and issue at all as long as she lets you join in IMO
Bullshit, GF making out with a girl is the same as her making out with another dude.... I don't see the difference
That's what I thought, I'm kinda biased on the issue ATM. What's cracking bunts
Oh and my shrug was a 'been there done that, gave no shits' shrug. Life's too short to worry about that shit.
