Mugabetown - Whoretownin' At It's Worst.
So I chopped a ve ss sedan before
Hahah as we rolled up he sawthe p plates on the rear and he and was all neutral and rev the tits off of it, just stalled it up like 3 seconds before the lights and launched
And when I got to the speed limit (90 from the hornibrook bridge to the deagon deviation)
He did the hero fly past and then me the scissors...... I thought.... When did nick get a new car
Ve ss's have a 6L V8 and make 270kw standard not only that but if by stalled up it had the zf auto means it's also a brilliantly quick box. Have seen many run low thirteens dead stock.... Confused as to how he could possibly have trouble against your car. :/
Yesh, I'm stuck here till 12 today... But I'm going out tonight so whoop whoop
I dont go out at all......
In other news, I headed down to see Noel yesterday and talk car stuff and check out his build... Definitely well worth the drive out there
Yes the cranky old bastard knows his shit :)
cuz bogan driver
    • Was that with the cas upside or correct way up?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
