Mugabetown - Whoretownin' At It's Worst.
*line up the cars for photo* *all crash into each other*?
this
It won't be a time attack Bodo. Me thinks you have skyline fever
bah, skirts :P
Yeah it's happy laps, I won't be going anywhere near fast enough to have issues, I just want to go for a drive with the ant eater!
lol, why do you guys all assume I need to be going far too fast all the time?
Especially with the chicane and a few cars on track, lakeside is safe. having said that, you can still go quite fast without any safety issues and hooking it through the witches hats as fast as possible is fun too
Morning all
Morning...slow morning it is too
Same same powahz as the abomb :)
less than half the displacement and at all 4 wheels I assume? or was it a 2wd dyno?
'As fast as possible' is not somthing I will be aiming at during Happy laps is all I am saying
Installed new Clamps... but don't really want to test them out. Got it up to 9PSI just on back streets around here (within limp home range) so I can drive the car... but i feel like i should get it to a QR happylaps or something to open it up properly, not the motorway where i can't get it off.
also, why the hell did nissan put the BoV's there.
Meh. Just take the necessary tools with you on the test run Pete. No need to wait for QR for that.
I guess i just need to pick a nice illuminated road with plenty of space on the side.. would get my legs run over taking the front bar off on the freeway!
That takes dedication, I'd presume doing around the letters must be a real pain in the ass?
it should be ok. A tooth brush will do the trick.
Not wrong re dedication but I enjoy it.
Got an idea about detailing the 'skyline' letters ;)
Secret for now
Secret for now
Nissan did have a factory option to add a red sticker that sat in the skyline letters on the rear bar. Probably wouldn't look too good on white but looks awesome on the darker colours
yeah seen them......looks like crap IMO
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
    • So 10/10 times that code is coil packs? I mean if that's the case ill drop the $400USD or so to replace them. I didn't know these cars threw codes before the issue became an issue.
