Mugabetown - Whoretownin' At It's Worst.
You went all the way down to see Matty Spry and didn't swing pass to say hi????
I also went to bed late paying for it now :/
Sorry to hear about your mates car Scottie.
What power did it make before she gave way?
534rwhp through a 3spd auto box on 28psi... Reading doesnt do it justice. Its quicker than my car
Unfortunately, when you do this with old engines, something inevitably goes bang.
Correct, If it didnt break on the dyno. No doubt we would have broke it on the drive home lol
It is what it is
It is what it is
Not necessarily. It's under strain on the dyno. You could have been fine on the way home and then blown it at QR. Good luck getting back to Bribie form there!
It is what it is
He would have given it a full boot on the way home on highway for sure. Loves going fast too much. But yeah either way would have blown last night or at Downshift on Sunday morning. Which wouldnt have been great for me as I have to go to work afterwards on sunday
  • Like 1
Lol. Fair enough. At least you have red bull.
Cruisung up a long hill in a high gear is also possibly more load than a lap at QR. Also being on the dunno is not inherently strenuous, for power runs the ramp rate is low and it's under very little load! LEAVE DYNOS ALONE *cries*
Morning all, trying to get a half day at work I'm f**ked between doing massive hours, trying to cut and lifting last night I'm f**ked :(
Cause auto ;)
(Makes you wonder why I'm not worried about Pete's powwah hehehe)
Cause auto ;)
Im starting to get tempted in the auto direction and im not sure i like lol
Don't say that, it's ment to be sunshine and lollipops... You trying to discourage me lol
Im not discouraging. Just advising
V... What, V! f**kING WHAT, V!!!
Get out!
Redbull fo life :rant:
I know i feel ashamed of myself. I cant justify $5 for a 355ml can of Redbull.
V was 4 pack of 250L for $7
Cause auto ;)
If it was from a standing start, instead of a rolling start where every single factor is in your favor, you should be worried about his powah, but I will say one thing for you, you choose your battles well!
Wonder why he tries to line me up then.. Delusional?
Thinking like Nick here, and it is scary, but I imagine he is hoping you will miss a gear, then he will never race you again :P
This actually happened at Downshift last month.. .Missed 3rd so he had me at half track. Got him back by the end though... Damn kids and there Auto V8's
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
