Mugabetown - Whoretownin' At It's Worst.
You went all the way down to see Matty Spry and didn't swing pass to say hi????
I also went to bed late paying for it now :/
Sorry to hear about your mates car Scottie.
What power did it make before she gave way?
534rwhp through a 3spd auto box on 28psi... Reading doesnt do it justice. Its quicker than my car
Unfortunately, when you do this with old engines, something inevitably goes bang.
Correct, If it didnt break on the dyno. No doubt we would have broke it on the drive home lol
It is what it is
It is what it is
Not necessarily. It's under strain on the dyno. You could have been fine on the way home and then blown it at QR. Good luck getting back to Bribie form there!
It is what it is
He would have given it a full boot on the way home on highway for sure. Loves going fast too much. But yeah either way would have blown last night or at Downshift on Sunday morning. Which wouldnt have been great for me as I have to go to work afterwards on sunday
  • Like 1
Lol. Fair enough. At least you have red bull.
Cruisung up a long hill in a high gear is also possibly more load than a lap at QR. Also being on the dunno is not inherently strenuous, for power runs the ramp rate is low and it's under very little load! LEAVE DYNOS ALONE *cries*
Morning all, trying to get a half day at work I'm f**ked between doing massive hours, trying to cut and lifting last night I'm f**ked :(
Cause auto ;)
(Makes you wonder why I'm not worried about Pete's powwah hehehe)
Cause auto ;)
Im starting to get tempted in the auto direction and im not sure i like lol
Don't say that, it's ment to be sunshine and lollipops... You trying to discourage me lol
Im not discouraging. Just advising
V... What, V! f**kING WHAT, V!!!
Get out!
Redbull fo life :rant:
I know i feel ashamed of myself. I cant justify $5 for a 355ml can of Redbull.
V was 4 pack of 250L for $7
Cause auto ;)
If it was from a standing start, instead of a rolling start where every single factor is in your favor, you should be worried about his powah, but I will say one thing for you, you choose your battles well!
Wonder why he tries to line me up then.. Delusional?
Thinking like Nick here, and it is scary, but I imagine he is hoping you will miss a gear, then he will never race you again :P
This actually happened at Downshift last month.. .Missed 3rd so he had me at half track. Got him back by the end though... Damn kids and there Auto V8's
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
