Mugabetown - Whoretownin' At It's Worst.
If it was from a standing start, instead of a rolling start where every single factor is in your favor, you should be worried about his powah, but I will say one thing for you, you choose your battles well!
Yes well... I don't like losing. It makes me waste money lol
Scott is Nick's Unicorn. The one he couldn't beat.
This actually happened at Downshift last month.. .Missed 3rd so he had me at half track. Got him back by the end though... Damn kids and there Auto V8's
Thinking like Nick here, and it is scary, but I imagine he is hoping you will miss a gear, then he will never race you again :P
Oh you mean.... Like this:
Bahahaha :rofl:
Questions for Scott,
Are you running E85?
Are you planning to/have done official 1/4 miles with your current set up?
Yes
No
Cars runs E85 only, however i have it flex tuned with sensor....
Yet to run it down the 1/4 mile. Still a few things I want to get changed and adjusted before I go
Yes
No
sweet, thanks! I plan on doing a flex set up at some point too, I am being told that 1000cc injectors wont be enough, I will probably only make 350rwkw max so possibly even the 750cc ones I have now may be enough.
Will be interesting to see what it can do!
I make 420rwkw+ and only run 1000cc injectors
Yeah i noticed that in your sig, people seem to be going nuts on the injectors for e85, yeah you use more but I was suggested 1200s which to me seems very very excessive, and your set up proves that it is.
I think people are moving towards the huge ones as the price difference is pretty much nothing. I think 2000cc ones were like $10 each more expensive for me. I originally went 2000cc injectors but due to 3.oL bottom end the Plazmaman Plenum sits very high in the engine back and the Fuel Rail was fouling on it as the 2000cc's were too tall. So we went smaller. Id say they would be close to their limit though
doubt that very much Bunts.
I make 350rwkw on 98 with 1,000cc.
Although I know that E85 drinks more I'm pretty certain that 400rwkw is safely achieved with 1000cc injectors.
It's the fuel pump that needs to be up to scratch to deliver ;)
In regards to pump, I use intank pump only. Walbro E85 one. Pretty sure this is the one
http://www.sonicperformance.com.au/F90000267/Walbro-Fuel-Pump-Intank-E85-450lph/pd.php
I has exactly the same :)
Yeah the fuel pump I have should be sweet, and I have a surge tank and lift pump ready too, I think I will give it a go on the 750s and cross the running out of flow bridge if I come to it.
Sounds like a good idea. I am not privy to this motor vehicle you are assembling. All i know is it has a Crank trigger setup [Which im learning more about and jealous of lol] and now e85 with a good fuel setup. Sounds like a cool machine in the making
yeah Bunts car should kick some serious bogan V8 ass once she's all done :P
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
