Mugabetown - Whoretownin' At It's Worst.
Sounds like a good idea. I am not privy to this motor vehicle you are assembling. All i know is it has a Crank trigger setup [Which im learning more about and jealous of lol] and now e85 with a good fuel setup. Sounds like a cool machine in the making
Its not going to be anything too special, the crank trigger is really just about reliability, after nearly 10 years of cars 'going out of tune' i just want a car that I can turn the key and kick it in the guts HARD every time with out fear of frigging knock lights ruining the fun! At he moment I am capped to running only 14psi with little to no timing, it made 306rwkw then so I am keen to see what the set up is actually capable of with a stable timing signal.
And if I dont like that I will build the RB28 I have wanted for the last 6 or 7 years!
yeah Bunts car should kick some serious bogan V8 ass once she's all done :P
Ha ha I doubt I will cross paths too often with any rigs matching that description, happy laps grand prix is not really my scene!
Is those figures on pump 98? I made another 100hp when i switched to e85 and only added like 3 psi
Strippers FTMFW... Especially Lesbo shows.
This is true
Yeah that was on 98. I think the physical flow of my turbos will be the limiting factor, they are only babies so I think they will be incapable of pushing more air at 350ish kw, though they have been modified from stock so their limit is a bit unknown.
Ants, what's that whisky recommendation website that you use? Also, have you tried Macallan 12 or 18 YO?
Its this website mate http://www.smwhisky.com.au/
Yes, I have tried both Macallan 12 and 18 fine oak and also tried the Macallan Sherry Oak. I also happen to own both ;)
Does it come recommended?
well its Macallan mate. She's like the Nike of single malts its very good stuff but I find the price hard to justify.
Its why in fact Macallan went down the path of introducing the fine oak range because production costs are lower using american oak barrels (bourbon) rather than sherry oak barrels, however even their 18yo was like $189 IIRC.
My thoughts are as follows:
Fine oak - cheaper than Sherry oak and is very fruity, makes your mouth water / dry and then releases beautiful flavors like vanilla, raisins and fudge
Sherry oak - very exy but my favorite but caramel galore. Could really go without that artificial coloring IMO but the tastes - at first its very spicy, but after you have drank a dram you get the following flavours, burnt cookie / creme caramel, spices like cardamin, orange peel and a hint of wooden smoke - truly amazing mate.
you can make your own recommendation but I think you know what to go for now.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
