Mugabetown - Whoretownin' At It's Worst.
Shocks, springs, sway bars and bump stops are good. Everything else i would be going adjustable arms (you can get adjustable arms with rubber bushes rather than spherical bearings). The sub frame alignment kit http://www.whiteline.com.au/product_detail4.php?part_number=KCA349 why would he recommend that rather than just replacing the 20 year old bushes?
Also what about the diff mounts, rear lower control arm bushes, bushes in the rear hubs/uprights and more i can't think of now. There are a lot of parts he has left out.
was going to get diff mounts, bushes after mate. As the coilovers and sway bars are more of a priority for me FTM.
Mr Ants, I recommend not doing coilovers and swaybars at the same time.
Makes for a really harsh ride. If your coilovers have hard spring rates, leave stock swaybars in and see how it feels. Likewise, if you have stiff swaybars, chuck them in and maybe go for a softer coilover.
Have a gingerbeer coming out on Thurs arvie Scotty, hopefully can get a roady and rego before the weekend. If so, I might get to the dyno day ;)
oh! I will take that under advisement.
Side note my garage door farked itself last nite.......can't even manually lift the door as it's 100kg and my powerlifting days are well and truly over.
Have to fork out money to repair it now so suspension needs to wait + the Jannica's car and the Ant-eater is stuck for now
Interesting...
The new F1's make 130ish dB. Down from the mid 140's of the V8's but far from quiet. Is it just the turbrah that kills the noise?
I don't care what the numbers say, there is no comparison. I went a few years ago and you NEEDED ear plugs. I didn't take any thinking "bah, I've heard race cars before, I won't need them". I was f*cking wrong and luckily I was able to get some at the track.
They had one old V8 there (RB7) doing the ultimate speed comparison and even just that one running was borderline on wanting to block your ears, but with all 22 of the new ones running you don't even get close to needing them.
dB is a logarithmic scale so a change of 10-15 is significant. But it's not just the volume but the nature of the sound, the old ones sounded just glorious while the new ones sound... agricultural?
I would not be complaining too much about the noise reduction Marty......you have been lucky enough to witness several F1 events live, whilst others have never seen them or may never get the opportunity to see them fly past at full blast
Oh shit. You called him Marty... You in for it now!
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
