Mugabetown - Whoretownin' At It's Worst.
Winning at mod plates! Front mount, turbos, noise tested, coilovers, adjustable arms, brakes, recaros, surge tank... think thats about it!
No roadworthy tho as he doesnt do them, but got a guy coming monday!
f**k yeah rego here we come
  • Like 1
That's great! Everyone was saying engineering was out the door with the new laws, seems as though that ain't necessarily the case!
I wouldn't worry about it. Pretty hard to tell on a low mount set up!
didnt Pete tell you? He's gonna bolt a T51R, NOS injected, twin gated into atmo, with screamer pipe on standard bottom end.
She's gonna be Pete's bulldog pocket rocket!
nice Zac. You know I also had the standard cam gears as well.
Those exhaust manifolds look good......but I would have stuck to OEM and got them ported
